Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
The bottom half of my screen is discolored and flickering.
Album: http://imgur.com/a/c66Ht
This morning, my bottom 2/3rds of my phone screen randomly started flickering, but it went away after 10-15 seconds. By afternoon, the entire half was discolored. Is this possibly a software problem?
The top corner of the panel is slowly separating from the body, if that helps: http://imgur.com/a/7iklg
Score 2
Add a comment
1 Answer
Most Helpful Answer
andrienalinerush, very unlikely that this is a software issue. Looks more like either a bad LCD or a connection issue. If your Glass and LCD are separating than you definitely should consider a new display panel. It is also possible that both are coming out of the frame which may caused be a swelling battery. You do want to use these guides to open up your phone and check the LCD connections, cables and connectors carefully. Also, do not forget the battery.
Score 2
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 26
All Time: 5,813
