Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 Questions View all
Question Closed
Removing bluetooth*step 26* screw will not budge*screw head w disfigur
I'm trying to replace a bluetooth in my macbook early 2008. In trying to remove screw to speaker in step 26 so I can get to the the bluetooth, I have damaged the screwhead because I tried every tool I had and still the screw will not budge. Too tiny and too much in the way to use a hacksaw.
It's the only screw in all those I've removed that is truly stuck. All this work and patience and I'm dead in the water. Any suggestions are welcome. Thanks! Mary
Add a comment
1 Answer
Chosen Solution
Engineer makes screw pliers that are cut so that the end can be used to grip a screw head. The Engineer PZ-57 Screw Pliers M2 ... Happen to be carried by iFixit in 3 different sizes. These are incredibly helpful.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 44
