What is a compatible SSD that can replace the HDD?
I have iMac Intel 20" EMC 2266
would like to speed up disk access by replacing with SSD
There are a couple of things I would do in this order (some you may have already done)
Once you get to this point your system should be back to normal. If you want to still upgrade your HD I would recommend going with a SSHD as it will be cheaper and offer many of the benefits of what a SSD does. Here is the drive: Seagate Desktop SSHD.
Follow this IFIXIT guide: iMac Intel 20" EMC 2266 Hard Drive Replacement. Don't forget to put back the thermal sensor onto the drive!
While one can install a SSD in this system as well. I don't recommend it. The cost vs benefit limits its usefulness. The issue is the smaller cheaper SSD's often don't have enough storage space to make the system useful. As you go up with larger sized SSD's the costs get higher a 1TB drive is about $450 US. Now think about the lifespan this system has. Are you going to own it for another 4~5 years? Will it still be working and able to run the programs you want to use? These are risks one faces when putting to much into an older system. As an example a 2TB Seagate SSHD is about $90 US & a 1TB is $60 US would be a wiser investment.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 136
