Why are two successive SSDs failing and what is the solution.
While at the end of the booting process, my screen went completely dark and would not finish the boot cycle. The machine continued to have a completely black screen, even with booting from various other sources (CD, Flash Drive).
However, once I removed the SSD, the machine booted from external sources and was recognized by my other laptop via the Firewire master-slave connection. Everything checked out (& I do mean everything) normally.
When I installed a new SSD from OWC, the new HD accepted the OS (10.8) without a whimper. Upon booting up from this disk after OS installation, the exact same series of events occurred.
Very briefly, some of the initial text was evident on the screen but within 3-4 secs, screen black and computer did not boot. Once again, removal of the now 2nd HD allowed the computer to be booted from external sources. Once again, the remainder of the computer checked out.
I can't ascertain the status of either SSD as I can't find a SSD tester set, like OWC sells for traditional HDs.
My question is this: Should I spend $200+ on a Logic board replacement or convert my MacAir into a doorstop? I appreciate any and all insight into this dilemma. Thanks!
3 Comments
Please give us the make and model number of the SSD drive. How was it formatted and the system installed?
by mayer
Also have you check the systems firmware is it the latest? Follow this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers
by Dan
My sincere apologies to both responders. Sometimes the real world takes over the digital one which happened to me. To mayer, it was my understanding that SSD are not formatted per se. The initial drive was the one supplied with the MacBook Air. The second drive from OWC was an Aura 120 GB. The OS installed on the first drive was Mt. Lion. The same system was successfully installed on the second drive without problems. On the next boot, the second drive behaved exactly as the first when it crashed. I saw the initial wording on the initial black screen then the black screen persisted. Like the first drive, upon removal of the drive, the system booted normally from an external drive. Everything other than the SSD was nominal, powered either from battery or adapter. The firmware in both cases was up to date. What I really need to know is whether the logic board is the only logical culprit.
by szheart
