15% Off Selected iFixit Tools — Limited Time
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Help itunes error 9
I can not Restore my iphone 6 due to an error 9. What does error 9 means and what i have to do to make it. NEED SOME HELP PLEASE.
Score 2
Add a comment
I believe that error 9 relates to some kind of fault with the internal storage.
No easy fix available.
Provided you haven't done anything to invalidate your warranty with Apple - get it back top them quick. They should see you right, and will likely give you a replacement.
Add a comment
Error (9) can me a multitude of different things. My error (9) was because of corrosion on the lcd flex cables that wouldn't allow the phone to boot, therefore I couldn't restore it. But when I unplugged the LCD completely I could get it to fully restore. Now my iPhone works, I just had to use isopropyl alcohol to clean all the corrosion off the PCD flex cable connectors. Sorry if I am bad at explaining im 16.
1 Comment:
Something similar myself.. I disconnected the rear facing camera whilst restoring and it worked absolutely fine.
by
Add a comment
Add your answer
Papo will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 6
All Time: 974
