The Xiaomi Mi 3 is a high-end, premium Android smartphone that is produced by Xiaomi.
22 Questions View all
Question Closed
What is easiest way to replace a bad usb dock charger
My charger cable will not mount securely and will not charge. cable connection seems to be loose. Can the dock itself replaced or teh whole ribbon assembly. What steps I can skip to doing that job
thank you
Add a comment
1 Answer
Chosen Solution
If the USB port is damaged and connected via a ribbon cable it is far easier just replacing the whole cable. Otherwise it would involve desoldering the broken one and soldering a new one on and this isn't an easier job unless you have the right equipment.
The guide below in Step 11 describes the part you would need to replace.
Xiaomi Mi 3 Touchscreen Replacement
Score 2
1 Comment:
Thanks very much
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 215
