Why is my iMac respond so slow?
my screen cracked so i running my iMac with dell S2340l monitor connected with HDMI adaptor through mini port. too bad the overall respond are dropped very very much....
I assume the screen cracked when the system was knocked over.
If that was the case it sounds like you also killed the hard drive. At this point I would strongly recommend you stop using your system and make a backup of anything important before the system fully dies.
The next issue is what is your plans here? To fix the system or replace?
Hi Dan, Thanks for the reply. I think the problem not come from hdd & ram bcos i did replaced both of it but the slow respond problem remain....
and yes, i wish to fix the system & all my file already saved. thanks for the reminder ya....cheers!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 155
1 Comment
Is the actual screen cracked or just the glass?
by mayer
