Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
Why outgoing call failed, while incoming, 3G data, SMS working fine
i have Iphone 5S with IOS 8.4.1 ,after installing 8.4.1 music patch , out going call getting failed, while all other things working fine(incoming call, SMS, 3G data) all working fine,
while i travel in roaming , and automating network switches to other network carier, outgiong calls as well working fine there, but not in home network(airtel india)
1 Comment:
i tried to date change manually and show my caller id setting followed by restart as well , but no luck, still no outgoing
by
Add a comment
1 Answer
Have you contacted your network about the issue? It may be on their side. If you have everything backed up try a factory reset of the phone, something may not have written correctly during the update, a reset should correct that.
Also I assume you have tried powering the phone down for a minute then powering it on again? Sometimes that actually can help.
Hope this helps.
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 569
