Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Questions View all
Question Closed
Why is touch screen not working?
I was replacing a screen on an iPod touch and had to replace the bezel. After I replaced the bezel and put the new screen on everything worked except the touch screen. I even put the old screen back on to see if it was a bad screen but that didn't work either. I think it may be the adapter but i'm not exactly sure. I have tried to reset it but nothing it working. Thanks.
Add a comment
1 Answer
Most Helpful Answer
Make sure you are connecting the digitizer correctly. If You are then look for damaged connector. I've seen a few where connector on logic board is damaged due to incorrect placement attempts
Score 1
4 Comments:
If this was the problem which it most likely is, would there be a way to fix the connector on the logic board?
by
Yes they are replaceable. This is the part you would need to buy http://www.ebay.com/itm/2X-Connector-iPo... This part replacement requires micro soldering. If you need further assistance let me know.
by
Thank you or your help I actually put the screen into the bezel and it started working fine. Thanks again
by
Nice! glad it worked, placing those can be tough sometimes :)
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 83
