Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Question Closed
Backlight off after disambling
Hello everyone,
I got an Iphone 3GS and i was Disambling the iphone to switch the Audio Flex Cable everything works fine til i tryed to switch the phone on after repair.
now the backlight dont glow anymore. i see phone is starting and so on just the backlight dont light.
so i bought a new LCD becouse i thought i damaged it anyhow. but still it dont show the backlight.
after that i bought a sensor flex cable and build that in.
but thats also not the error.
i dont know what i can switch now to get this backlight working again.
pls if anyone have an idea i will try that.
best regards
benandro
2 Comments
I have this same problem. Did you ever figure something out?
bizuzzi@yahoo.com
by
Helo Folks,
I got same same problem, i got one 3gs to replace flex audio cable, for silence button probme, them when i reassemble the backligth turn on 1sec and turn on when boot,...
When i dissasemble it first time the lcd cable had damaged, then i must replace it for a new one, then that happens...
The big problem is the iphone is not mine, is from costumer who take to me fix flex audio cable, now that...
I very worry now i must give the iphone to costumer and it not working well :( and here in brazil a 3gs is very expensive like 500usd and a secondhand 300usd damnn :(
Pls help
by
Add a comment
Most Helpful Answer
you could try to reset the phone (press and hold the sleep and the home button until the phone restarts) - BUT - that might not help at all.
the iphone 3g/3gs are very problematic and a very common problem is a coil that get toasted when the phone was not shut down while tinkering.
the things you are describing are pointing to exact that problem.
it is fixable - but only for a "guerilla-pro". it could get pricey too - to fix this phone - another one has to die.
update
i've found a different fix, but it's not easier to do
update 2
here are the 2 fixes
the first is with replacing the coil - that might be the better fix
the next one is with a jump wire, sounds easy - but its not, the soulder joints are tiny and nobody knows exactly how long this fix will work (and the logicboard might be toast after that)
i took the pictures from a gsm page - so don't ask about high-res. pictures - thats everything i have.
Score 1
11 Comments:
wow i will try that out.
thank you for your help
i will let you know if it worked
by
ok, good luck - but be careful - the parts are tiny
by
i think that was not the problem, i forgot to say if i switch on the phone the display backlight showes up for 1 sec and then stays off linke a blink at the apple symbol on start just for 1 sec maybe less.
by
did you try to reset the phone?
by
Show 6 more comments
Add a comment
Add a comment
I updates the phone from 3.1.3 to 4.0.1 im Not sure if this Count As reset aswell?
If Not i also disambled the phone completly and waited 2 hours bevor i ?reambled? Everything again sorry for my english.
Best Erhards
Benandro
Add a comment
Helo Folks,
Pls help
Add a comment
bizuzzi@yahoo.com
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 8,859
