Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
iPhone 5:Cellular distortion in mic after mic panel replacement.
i have replaced the mic panel of my phone, and started to face the strange problem, when recording on voice memo there is no distortion, while on cellular call it makes distortion, which is heard by the other person, and it's soo loud.
Add a comment
1 Answer
The microphone for notes can be using a different microphone while the one for calls unless you are on speaker is using the bottom microphone. If by replacing mic panel you mean the charging port then make sure you transferred the rubber gasket for the microphone to the new one. If this is correct then get the part out of the frame and while connected to the board test a phone call. If everything is good then you know something during assembly is not being placed correctly. If you still get the same problem then try another part. Hope this helps!
1 Comment:
this makes noise only on cellular calls, not calls over the internet, e.t.c, yes i have transferred the rubber gasket too. I think i have to try another part..
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 124
