The aluminum PowerBook G4 was released by Apple to replace the previous titanium-body model. The 12" and 17" versions debutted in January 2003 with the 15" version following in September of that year.
683 Questions View all
PB G4 Aluminum, 1.5 GHz ppc: bottom 2/3 screen blanks out
The bottom 2/3 of the screen blanks out until I adjust the screen on its hinges. Problem is getting progressively worse. External monitor does not have same problem, I suspect failing connection?
Score -1
Add a comment
Chosen Solution
Probably the cable from the logic board to the LCD is going bad since the problem changes when you move the screen. Since I don't know which 1.5 you have I can't leave a link to a specific guide. I am however leaving you a guide to help you pick out your model. Good luck. Ralph
PowerBook G4 Aluminum
Score 4
2 Comments:
Oh well fellow - we seem to have anwered at the same time. Point for you ;-)
by
Add a comment
You might have a failing LVDS (video signal) cable. iFixit doesn't seem to have it in stock (correct me if i'm wrong) but you can find one here.
Score 2
1 Comment:
Add a comment
Add your answer
Darryl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 575
