Released April, 2014. CPU - Quad-core 2.3 GHz Krait 400, GPU - Adreno 330. Display - IPS LCD, 16M colors, 1080 x 1920 pixels, 5.2 inches. Internal memory - 16 GB, 3 GB RAM. Android OS, v4.4.2 (KitKat). D6502, D6503, D6543
57 Questions View all
Question Closed
after replacing the screen, hotspot and bluetooth are week signal
after replacing the screen, hotspot and bluetooth are week signal, I would like to know where is the hardware part of the devices that manage bluetooth and the hotspot ( wifi share ) to check if it is ok, the signal is so weak that if I am using bluetooth and I walk 3mtrs the connection ends same for hotspot
Add a comment
1 Answer
most likely you didn't connect the coaxial antenna cable properly. Disassemble your device and check connections.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 89
