Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
Black screen, backlight problem?
I recently dropped my iphone 6 in the sink briefly. It was water damaged as the LCI shows red. I can still charge it; see it in iTune; and if I shine a flashlight on it, I can see the display, but the screen appears black without light.
Does it mean backlight fuse is burned? If so, I don't think I can do it without some real fine tools and micro scope. How much would it cost for the repair shop to fix it?
Thanks.
Score 12
1 Comment
Thanks for the answers. The reason why I suspect it being the backlight problem is that I can still see it clearly with a flashlight, and I can gesture and all the things. I thought if there's an LCD issue, I won't even see that.
by
Add a comment
Most Helpful Answer
Could just be the LCD. Clean the logic board and try another LCD
Score 1
Add a comment
If the screen looks very dark but you can see the screen while using a flashlight or looking really closely its more than likely a backlight coil on the logic board so a new LCD/screen wouldn’t fix it. You’d have to take it to a repair shop that specializes in microsoldering and board level repair
Score 1
Add a comment
I would try another screen. I would rule that out before venturing into the backlight repair. Also, look at the connector when you take it apart.
Add a comment
So I could be wrong . But it will be easier if you join fellow detailed pictures . If they are filters that will have a different color .
Add a comment
Add your answer
Joe Zhao will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 10
All Time: 28,710
