Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Power/Lock button is jammed and not very responsive
I have and iPhone 3GS and the power/lock button is not working as it once did. It is slightly jammed and needs more force than it originally did.
I would like to know what exactly is causing the button to stop clicking.. Is it that the aluminum contacts inside have been flattened?
I haven't dropped my phone but I am using the Speck Candyshell case and I suspect that due to its design it has put too much pressure on the button over time.
Score -1
Add a comment
1 Answer
Most Helpful Answer
the actual switch is made of 2 thin tin foils - they bend over time - so most likely the constant pressure bend the foil.
it might be possible to bend it back - i did this many times on cell phones - but the easiest way would be to replace the whole headphone jack assembly (but that's a little bit pricey)
Score 1
Add a comment
Add your answer
Tak will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,240
