iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
Why do I have a gray horizontal line on my screen?
I have a gray line about one pixel thick that goes horizontally about half way across the screen of the iPod. Where should I first look in diagnosing the problem?
Update (12/14/2009)
I apologize for the terrible picture quality. The line is between "backlight" and "brightness". It isn't a crack in the screen. Thanks for the responses.
On a side note:
Any idea what causes this issue?
Score 1
4 Comments
Can you post a picture so we can see if it looks like its damage to the actual screen or not?
by
My ipod had multi-coloured lines across screen. Followed instructions to hold down on-/off button at same holding centre button until apple symbol appears. Did it a few times, nearly gave up but eventually the lines cleared. THANK YOU.
by
broken inside screen
by
just a guess but i figured it would be bigger
by
Add a comment
Chosen Solution
Q: is the gray line there no matter what is being displayed?
I would guess it's likely a hardware failure in the LCD module, more specifically one of the outputs of the LCD row drivers, as I described in my answer to a similar question
unfortunately it's unlikely you'd be able to repair this yourself without replacing the whole LCD display module.
one thing to try - does slight pressure directly on either edge of the glass where the dead line is bring it temporarily back to life? - that might mean it's just a physical break in a connection of one output. bad news is it's likely impossible for you to resolder, the drivers are often bonded directly to the glass.
Score 2
1 Comment:
I hade the same thing on my 7th gen iPod nano. They looked like dead pixels but they weren't. Then I got these dots on my screen after a long time of using it day after day the lines went away.
by
Add a comment
I have a white lines going across my iPod touch 3rd generation and when I lock my screen and my screen goes white HELP!!!
2 Comments:
I have white lines going across my iPod touch 3rd generation and also when I lock my iPod the screen goes white ..., HELP!!!
by
The iPod nano 3rd generation has screen problems.
by
Add a comment
Add your answer
Reese Reimers will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 25
All Time: 26,716
