plug replacement wire type SJTW-A 3_16 FT 1 for beer cooler fridge
need to put new plug on cord but i think i need special type of plug is needed commercial type bar beer cooler any info would be great.
It's a standard 3 prong plug. Positive, negative and ground. The wire is 16 gauge and looks to be 1 foot long.
SJTW
Hard service cord. Thermoplastic constructed jacket. 300 volt, weather resistant for outdoor use.
Could be a 220 volt with the black and brown hot.
http://inspectapedia.com/electric/Wiring...
Please give us the make and model number of the unit.
cornelius manufacturing co ltd toronto canada. model 47001 0216 serial r900136642.
g r12 test press: ls 1034 kpa hs 2069 kps
oz r12 test press ls 150 psi hs 300 psi
volts 115 hertz 60
amps 8.3 phase 1
mayer i wrote down as much info i could on further inspection of wires it seems colors are black grey and cream. thanks for all the help so far martin
It makes a difference. The gray is a substitute for white. Strip the wire up a little bit to see if the color changes. Time may have aged the wire.
See if there is a number like COR10DBD1T. Please take a look at the insertion point on the cooler and identify which line is grounded out or attached to the frame. Then we can talk about how to wire the plug. Also please un-accept my answer till we get the problem solved. It is a standard 110/115 plug not a 220/240. We want the correct wire for ground and do not want to reverse polarity. I'm not sure why because at the breaker box both ground and white are connected to the same bar, but let's do it according to code.
stripped wire its standard white,black,green i had put new plug on and wired it black {hot} white{neutral} green{ground} the reason i asked if a special plug was needed was because i noticed some burn color on hot terminal its a very old cooler type you would see in store for cans or bottles of pop we use it at work when we have a function.
Third color change on the wires. Here's the video you need: https://www.youtube.com/watch?v=tva8k4Er... Now you can accept the answer. Thanks
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 359
2 Comments
Beer cooler huh? I think I'll have to see this one in person. OK, maybe a picture would do.
by mayer
its a beer cooler at work wire colors are black, brown and cream 3 wire not sure which is hot,ground,etc which is why im asking if special plug is needed thanks martin
by martin
