Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Does iPhone 6+ LCD is replaceable?
Hello everyone.
Just little question, i've seen many peoples talking about changing the LCD of iPhone 6+ will make the home button stop working, and device will not open after for the error.
So, as you can see here, iPhone 6 Plus LCD and Digitizer Replacement
At the step 32, we have to peel the button flex (highlighted in red in the second picture), so does this "button flex" on the LCD are sticked to the LCD or sticked to the metal LCD shield ?
And does we can repair iPhone 6 Plus LCD without changing the original button, and make it work like a new, including touch id function?
Thanks
Score 3
Add a comment
Chosen Solution
If you keep the original home button and put that on your new screen, you will be fine, changing the home button will cause error 53. :-)
Score 1
1 Comment:
Yes i know for that, like the 5S...
But, i don't really understand what to do at the step 32, "we have to peel the button flex (highlighted in red in the second picture), so does this "button flex" on the LCD are sticked to the LCD or sticked to the metal LCD shield ?"
Thank ?
by
Add a comment
in that step, you are releasing the connector from the adhesive that holds it to the screen. Once it is free from the screen, it is still attached to the metal plate, but you just remove the metal plate and flex together, as they come out as one piece (see pic)
Score 1
1 Comment:
Amazing, thank to you!
by
Add a comment
Add your answer
Phonetech93 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 15
All Time: 669
