The HP Deskjet F4480 Printer/Copier/Scanner. This printer was intended for home or small office use.
19 Questions View all
Question Closed
Print but will not scan.
Will print, but not scan. When I press the scan button, the green power light flashes and a red light flashes right at bottom right of the button choices. Went on line and reinstalled. Checked connections. Any ideas?
Update
installed twice still does not work. When I push SCAN the bar tries to moved but goes back
Add a comment
1 Answer
Did you try to re-install the drivers?
Add a comment
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 4
All Time: 191
