Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
164 Questions View all
Question Closed
HDD Heat Sensor Issue
Hi, I replaced my 1tb hdd with seagate 2tb sshd and now the fan is going flat out. I changed it back to the old hdd and still the same issue. Please help. I replace the cable sensor the same way, still issues.
Add a comment
Most Helpful Answer
I don't recommend software solutions to control the fan's as they are not dynamic enough. You either end up killing your fan or overtime you overheat the system. Both are expensive repairs that if you correctly ID the problem wouldn't be needed.
But before we go into how to fix this lets see if we can gather some more diagnostic information to locate what needs service here. Download this app: Temperature Gauge Pro. Post a screen shot of the temp sensors & fans into your question so we can see whats up.
Score 1
Add a comment
Macs Fan Control is a great program. It tamed my fan when it was blaring. Just open it and set a speed and it'll slow that thing down.
Score -1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 113
