Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1699 Questions View all
Question Closed
Refrigerator is leaking water inside but the drainage is not clogged
Maytag Performa Refrigerator Use and Care Guide - 61005299. I have cleaned the drainage tube and the refrigerator is tilted to the back. But the water freezed at the opening of the drainage and clogged the drainage. The water freeze and block draining tube. I turn off the refrigerator and melted all the ice in the freezer. But the water that comes form the freezer freeze again blocking the draining opening. Could anyone suggest what is the problem? Thank you.
1 Comment
There is a problem. This refrigerator does not have ice dispenser. It have the freezer at the top and the refrigerator under it. Could it be that is low on refrigerant and that is why is building ice on the evaporator? Thank you.
by
Add a comment
1 Answer
Chosen Solution
Check to see that the flapper door to the ice dispenser is closing completely.
Score 2
1 Comment:
Ice build up on the coils is a sign of low refrigerant.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 611
