Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1702 Questions View all
Question Closed
Disable Water/Ice Dispenser Totally (GE Refrigerator PSC23SGMDBS)!
Many, many problems with this in-door dispenser. Is it possible to totally disconnect all dispenser functions but still allow the ice maker to work? In other words, not shut the water off at the valve behind the refrigerator, shut it off somewhere where just the dispenser is affected? Tired of leaking, accidents, noise, numerous repairs - I prefer to open the freezer door and get ice. I don't need this troublesome, unnecessary feature.
Add a comment
1 Answer
Chosen Solution
Trace the line back to the source and cap it off.
Score 2
1 Comment:
I've disconnected the water line under the freezer door. There's a quick connect coupler there. The supply side does not appear to be leaking but if I do cap it might there be a buildup of water eventually , somehow in that tube?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,137
