Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Not working phone after drop
Hi.
I just bought a cheap broken Iphone 6 from someone i know. She dropped the phone, and the screen was cracked and the phone was "dead".
They had tried everything they say, connected it on a computer to get pictures backuped.
First thing i did when i bought it was to test another broken screen, the phone booted up normally, and everything seemed to work fine. (a very good deal for me)
But when I connect the home button flex on logic board everything goes red. And if i turn the device off and connect the flex, it wont turn on.
I also found at that the old cracked screen works well if the home button flex is disconnected from the logic board.
EDIT:
No physical damage to the ribbon cables on the home button flexes whatsoever.
Score 1
1 Comment:
Ok, got my new home button flex cable today. The home buttons works but i'm getting the Itunes 53 error. I found out that something on the Home button connector has fallen off. Is there a way to fix this? I have the small part that fell off, and it perfectly fits in the defective connector.
I guess buying a new home button on ebay will not work?
by
Add a comment
looks like somehow the gold ends of the connector somehow got loose during the drop and are possibly touching causing it to short circuit.
I also have a question
Can you make sure that the finger sensor is connected properly to the back plate on the LCD
Add a comment
I was checking the connector you asked about, and it just fell of. Seems like the corrector on the home button back plate was very weak. I hope it was this causing the problem. Will it with another backplate asap.
Add a comment
Add your answer
lekice will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 2
All Time: 335
