Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
iPhone 5s only charging with cheap plug and not using Apple one
Hello!
My iPhone 5s is only charging if i use cheap plug but not using Apple one. Here i explain the whole story:
I bought an iPhone 5s which was not charging. I was first hopping that i could clean the lightning port for fixing the problem (and making money easily :) ) . Cleaning the port did not change anything. Then i bought and install a new lightening connector, nothing change and new battery. Then the phone charged but the battery life was 3 hours. I suspected my cheap plug was reponsible for poor battery life so i bought an Apple plug. Here surprise the iphone is not working with the genuine plug. "accessory not correct" message and not charging. If i use the the cheap plug it's ok...
I suspect motherboard problem but what do you think?
Add a comment
1 Answer
Chosen Solution
Hi am not 100% sure but reading lot of stuff on internet and asking a NY specialized shot it appears that the problem come from the motherboard. A chip call u2 ic is damaged and need to be changed. As there are not lot of skilled people around my place there is nothing to do...
1 Comment:
There is a very active member of this site who does this kind of work. As i may not advertise i cant tell you who, mysterious huh ;), but if you search properly on ifixit your iphone may be rehabilitated.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 125
