Repair information and guides for the fifth generation of iPhone. Model: A1387
Front facing camera shutter stuck?
Hi,
I'm having some real issues with my phone at the moment. I've just done a screen replacement and just as i thought all was finally fixed, i went onto the camera. It first appeared to work fine (this being the back facing camera) however when switching to the front facing camera the shutter doesn't open at all. Here's a picture of it :
It's annoying as always when you fix it, another thing happens. I'm not too sure what's happened with the camera as the phone wasn't in working condition when i bought it, so it may have been not working before i got it. It just seems to be the front camera that's gone wrong somewhere along the line.
1 Comment
UPDATE: Just replaced the front camera and that hasn't worked!! I now have no idea what to do..
by
Add a comment
Chosen Solution
First make sure nothing is obstructing the camera on the new screen that you installed: remove the camera and look against the light.
If that's not the issue, use a magnifying glass to examine the board mainly next to the front camera connector, but also next to all the other connectors in that area. Let us know if you find something missing/damaged/corroded.
Score 1
Add a comment
Make sure the front camera cable is properly seated on the mother board. It also possible that the cable was damaged during the repair and may need to be replaced.
1 Comment:
Thanks for your reply. I've checked and it seems that the camera connections are connected to the phone fine. I tried taking it off and on again ,but no luck. I've just ordered a new front facing camera now so hopefully it'll work! Thank you
by
Add a comment
Add your answer
Stewart will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 224
