Does the front camera kit fix a cracked front camera
My front camera is cracked, will purchasing the front camera kit replace the actual camera screen?
9 out of 10 when you see a crack on the front camera is most likely a crack on the screen and not the front camera.
Your front cam is hard to crack. It sits underneath the glass of the screen of your phone.
If you see a crack when taking pictures, it usually means the glass screen protection or the screen itself is broken, or there is something lodged between the front cam and screen.
My guess is, if the front cam is indeed cracked, it will not show an image.
However, if you did remove it from the phone and you can see that it's indeed broken, then yes the front camera kit will allow you to replace it.
Thanks! I took out the camera and there was a crack all the way across it, and when I replaced it, it also fixed my speaker issue!
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 5
All Time: 2,713
3 Comments
Hi was my answer helpful? do you need any more help?
by Sunny
My front camera was indeed cracked when I took it out, but thanks!
by Jessica Queen
How did you fix it? I'm having the same problem
by Leah Silas
