1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162 Questions View all
Question Closed
faulty lcd backlight replacement
hi, i just replaced lcd of my macbook air, while replacing lcd, accidently i scratched its backlight sheets, i searched that sheets everywhere, but i did'nt found them. could any one tell me what do we call to those sheets??
1 Comment
i can't open it now, but i can tell u in steps how i did it:
i took an old lcd of laptop, then i took it apart and then i took one diffuser sheet of mac and used it as reference to cut sheets of laptop lcd diffusers, and i used it in mac, but last time i cut these sheets one by one, due to which dust got into it, now m planning to cut them in one single attempt to reduce dirt to get in
by
Add a comment
1 Answer
Chosen Solution
We call them a display assembly, because anything you do to try to fix your current assembly will end in a nightmare. As you place the sheets more junk will get between each one, as you try to align them it all turns into a mess. The first thing to do is to not mess up the sheets. The second thing to do is to replace LCD assembly if you have messed up the sheets.
If you really want to go bonkers, cut open a broken LTN133AT09 and use a construction paper cutter like the one in third grade arts & crafts and use that to cut the internal light diffusors in the broken LTN133T09 to the exact measurements of the ones you &&^&@@ up, and put them into your air. It is possible.
But you really want a new display assembly at this point, because that will be a complete nightmare.
2 Comments:
thanx for reply, i have done this thing, i took one old lcd and cut sheets from it and placed them in mac and it worked
by
Can you show us some pictures of what you used and how it was done? I have never demonstrated this and it may help the countless others who have this question. Many think I am full of $@$* when I say just cut open another LCD and cut sheets with construction paper cutter, but IT WORKS!!!
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 370
