Model A1237 or A1304 / 1.6, 1.8, 1.86, or 2.13 GHz Core 2 Duo processor
313 Questions View all
Won't boot up and bleeping
Laptop fully charged when switch on it bleeps just one bleep evenly spaced out. Therefore it won't turn on. I believe it may be ram fault.????? Tried all of the press down button tests . Nothing appears to work I'm thinking logic board replacement but can I put in a logic board with 4gb currently 2 or will this not work or fit any ideas for both the possible fault and change of logic board
Score -1
Add a comment
Chosen Solution
Thank you I realised the ram and logic board come together. And was thinking along those lines thank you very much
Add a comment
Most Helpful Answer
The RAM on this model is integrated into the logic board. Check the price of the logic board and if it exceeds $325 consider getting a flat rate repair directly from Apple. (this is if the machine has not gotten water damaged. Apple will fix any and all problems the machine has for this flat rate.
Score 1
Add a comment
Add your answer
Gilly will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 122
