Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Apple logo blinks on battery insertion, water damaged iPhone.
So after doing what you said (clean with IPA), the screen still flickers on for a split second. If I shine a torch on it then its visible that the lcd and touchscreen work, just the backlight doesn't. Is there anything I could check on the motherboard to fix this?
Score -1
1 Comment:
also the dock connector is brand new, the phone's battery does charge
by
Add a comment
1 Answer
Clean the motherboard with isopropyl alcohol 90% using a toothbrush to remove corrosion on the motherboard circuits.
If you are unable to remove the corosion, there is nothing to do, the motherboard is no more working ...
Add a comment
Add your answer
Nikita Filippov will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 55
