Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2970 Questions View all
iPhone 4S gets hot without any reason.
Hello,
I have a problem with my iPhone 4S. Suddenly three days ago it gets hot without any reason.
After some tests I can tell you that it gets hot when
- the screen is on (even with iphone in airplane mode)
- the iPhone is charging (and screen is off).
Note that the warm side is the motherboard side.
When not charging and screen off , it is OK (cold).
To be sure that it is a hardware problem, I restored the iphone with the latest iOS (from 7.1.2 to 8.3) and the behavior is the same. It doesnt seem to be a software problem.
Have you any idea about this issue ?
thanks
Sergio
Score 1
Add a comment
GIVE TOOLS. FIX FOREVER.
GIVE TOOLS.
FIX FOREVER.
Spread the Fixmas cheer.
Can you observed any liquid damages on logic board? if answer yes : clean the logic board and try
if answer No, Check with anther Display module and let me know the result (according to your description i think fault coming from your LCD backlight or backlight driver)
Add a comment
Thanks for your reply.
Not sure it could be that. when charging the screen is off but iphone hot.
at the moment I do nothing because the iPhone is usable as it is. I will see next week-end.
[Edit] The component which overheats is just under the A5 chip. It seems to be a chip called D1815A4-C23-VAN2 (but obviously not sure).
I dont know what it is. Some russian site sell it !
http://i-chasti.ru/iphone-4/98--iphone-4...
Add a comment
Add your answer
Sergio Bzh will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 165
