Repair guides and disassembly information for laptops manufactured by ASUS.
2523 Questions View all
ASUS UX32V Notebook Internal HD to SSD: what about existing SSD
I consider to replace my ASUS UX32V internal hard drive with an SSD, but how will that interfere with the already built-in 24 GB SSD. Should I simply circumvent the 24 GB drive and how do I do that?
Score -1
2 Comments
Are you talking about 500GB With 24 GB SSHD, isn't it?
by
Yep, 500 + 24 GB
by
Add a comment
1 Answer
Most Helpful Answer
assuming your 24gb SSD is your (C) drive, just plug in your need SSD in the 500 Gb HDD slot and you should be good to go.
Score 2
2 Comments:
The 24 GB SSD has no drive letter. It is controlled by a program called ExpressCache.
by
ExpressCache is a program that copys frequently used HDD files to the SSD to read and write quickly. to answer your original question, you should be able to format the SSD and remove you old HDD and put the new SSD in its place and put the OS wherever you want. you would then be using 2 SSD's
by
Add a comment
Add your answer
peter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 536
