Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
AHT Error 4SNS/1/40000001:VP0R-0.000, suddenly shut down, while bootin
Hi
I´ve a big Problem with my MacBook.
When i start the macbook it doesnt boot. i see the apple sign and then shut down.
Score -1
Add a comment
Chosen Solution
Was the power adapter hooked up when you ran the test. If not, charge the battery fully, then hook the adapter up and run the test again and let us know your results. Next reset the SMC and run again and see if the results persist.
Score 1
Add a comment
This error indicates that a Voltage Sensor is not working. You may need to replace it. I would say you should probably check out the shops near you for such problems.
Score 1
Add a comment
Add your answer
Christopher Manske will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,519
