Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Battery replaced phone keeps powering off itself
Had the battery replaced. After each charging, the phone turns off after a couple of minutes and i have to turn it back on. After another couple of minutes it will turn off again. This can go on for 10 cycles or more. Sometimes however the phone works fine except the battery percentage display doesn't drop at all. Stays at 100% until it dies
Score 1
1 Comment
I have a similar problem after I replaced the battery purchased from iFixit. It keep powering off, won't turn back on until I plug it in. When on, the battery status display still have reasonable power level.
by
Add a comment
1 Answer
Most Helpful Answer
The new battery is defective, or you damaged one or several components on the logic board when you replaced the battery. Only way to know is to test with yet another new battery.
Score 2
Add a comment
Add your answer
rhysclemson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 67
