iPhone 3G - WiFi-Problem - antenna problem?
Hi,
my iPhone 3G doesn't find any WiFi network anymore. Apple Support says, that it might be the WiFi-antenna.
How do I repair the antenna?
bye
Mario
Hi,
bye
Mario
"it might"... or might not!
first of all - even without an antenna - you should be able to connect to a wi-fi network if you place the iphone beside the router.
if the iphone doesn't find any network - it's not the antenna!
does the iphone show the mac adress in the settings menu? (settings/general/about and then look at wi-fi adress)
+ good
Yes, it shows the MAC-adress. Does this mean, it is not the logic board?
im guessing you all updated to 0S4. 0S4 has been causing this problem on a few of my 3G's. List of what to try in the appropriate order:
try ejecting the sim, powering down and rebooting.
go to settings - general - reset - reset network settings
go to settings - general - reset - reset all settings.
toggle your airplane switch on and off (if that does not work turn airplane mode on for 3-5 minutes then switch back)
turn off location services and auto push
do a full restore
if the problem persists, i would just wait a few hours, change wifi locations, and run a restore. if the restore doesn't work right away, wait a while and try again.
downgrade to 3.1.3 if your savvy enough.
*as a very last resort you can always try a hard reset; hold down the power and home button for ten minutes straight.
downgrading to 3.1.3 isn't an option for 99,9% - and the rest will end up with a crappy baseband
Hi i have the same problem and it does show the mac address so that may be the wifi antenna
yes - if the mac adress is shown - the wifi chipset is ok, i would check the connector and if that is ok, relplace the wifi antenna
i also have the wifi problem on my iphone 3g, buy i don't see any address on wifi address settings... it is all blank...
wifi router name displays but just message popups "unable to join network"
iphone 3g network signal strength very loose solution
Hi, i also have an iPhone 3g with wifi problems. I tried the oven trick twice (first time the oven wasn't hot enough, and got to scared, haha) and the second time i got wifi running for about 2 days. After 2 days i intermittently got wifi access. Sometimes I just couldn't find any networks at all, and then all of a sudden i could, with 3 bars connectivity... I checked connector 6, but i don't think there's anything wrong with that. I also have a wi-fi-adress, this is the same as amac-adress right? Could this mean i have to replace the wifi antenna? Would that fix it for me?
I'd appreciate your opinion! thanks in advance!
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 10,730
