replacing the HDD with an SSD
Is it possible to replace the HDD with an SSD on my HP G71?
Yes you can.
You'll get some performance improvement after SSD replacement as the systems CPU & memory will limit you. You will gain more run time using the laptop in battery mode, than running with a HDD.
Modern SSD's come with auto sensing SATA III (6.0 Gb/s) interfaces. Your systems chip set only supports SATA I (1.5 Gb/s). The SSD will sense this and run at SATA I (1.5 Gb/s) speed.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 782
