Model A1204 / 1 or 2 GB capacity
74 Questions View all
Why wont my iPod turn on?
I was laying in bed listening to my Ipod Shuffle(second generation), when all of a sudden it just stopped playing music. I thought it had died, but when I went to turn it off, the light wasn't blinking red, or at all for that matter. I tried turning it off and then back on, but it still will not turn on. Is there any way to fix this? )=
Score 4
Add a comment
Most Helpful Answer
try this, remove ipod from dock, and move the power switch on the bottom of iPod shuffle to the off position. give it 10seconds and then move the power switch to the "on" position. The green stripe will be visible. :)
Score 2
Add a comment
let me quote something from your question:
"I thought it had died"
i think you're right, but you ment that the battery was empty - i think that the battery simply died - as in dead, passed or "moved on" (re-incarnated in a zune battery)
many ipod's are simply dead when the battery dies - the won't be recognized by the computer - as i said - they are dead.
you can order a new battery on ebay - if you order it in china, the will cost around 4$ (tools included).
surely - there is the possibility that there is some othere defect - but replacing the battery is the only thing you can try - everything else would mean to replace the logic board or the whole ipod
Score 1
Add a comment
I have the same problem it wont turn on or charge.
Score 1
Add a comment
I had the same issue and thought to sell it or try to fix it, but quite honestly it is just easier and better to replace it if nothing else is available. The cost to get everything to fix it is going to come close to just getting a new more modern version. Remember to recycle it though if you decide this is best for you.
Add a comment
my ipod is only displayn ok to disconnect what should i do
Add a comment
This is simple, try turning the switch OFF when you put it into the dock.
Add a comment
Add your answer
Tevin will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 18
All Time: 12,874
