The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3541 Questions View all
Home Button not working, TouchID working
Hi,
I've replaced my iPhone 5s battery. After the replacement, my home button is not working, but my TouchID is working :( I've checked the cables, but nothing seems to be damaged.
Any solutions?
Edit: I've also noticed that the sound does not work well when I use headphones.
Score 2
Comments:
my problem is a little different changed the battery the only problem is touch ID works but home button wont click??
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
1)i guess narrow damage should have in reborn flex cable or connectors, check again
2) you can dis assemble key and there is key dome switch which is taking pulses and it is covers by plastic cover. check inside of dome switch whether interfaces corroded or any internal damages to the flex cable
3) disable all securities in the phone and replaced the Home key
Comments:
Hi,
I've checked cables and other parts. Everything seems fine. What I've noticed is that many functions of my device is not working. Speakers and microphone, headphone jack, etc.
I'm starting to think that I've damaged motherboard:(
by
Oops! there should be something wrong with logic board. run diagnostic by apple certified technician
by
Add a comment
Add your answer
mzaferyahsi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 210
