Repair information and guides for the fifth generation of iPhone. Model: A1387
2201 Questions View all
Question Closed
wet damage but slightly works?
okay so my iphone 4s got wet. im not sure how wet, i attempted to get water out but didnt notice any. at first it came back on fine charged but it will only work for a VERY short period of time before the screen goes black. speakers are fine and when the screen does come back on it looks perfectly fine (then goes black).. please help :( !!!
Add a comment
1 Answer
Most Helpful Answer
For the sake of your phone please STOP trying to turn it on!
At a minimum, you will need to get a new battery. The battery is the 1st thing to get ruined or short out when wet. When that is replaced, it will most likely turn on, but you are not out of the woods...
Your iPhone's days will be numbered but a few, depending on the extra steps you take.
Just because it turns on now doesn't mean it won't crap out a few weeks down the road...
Resist the urge to turn it on for now. You (or someone qualified) should remove the back cover (2 bottom special screws) and disconnect the battery to prevent damaging corrosion on your circuit board.
You need remove battery power and your circuit board needs to be cleaned in an IPA (alcohol) bath. If you're willing to take an extra step to protect your iPhone, you should get a professional "Ultrasonic Cleaning" and a new battery. If corrosion found on the logic board is minimum, many potential problems are eliminated.
Sometimes, peripherals such as cameras can also start overheating or cause battery problems after liquid exposure, too. They can be disconnected or replaced.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 76
