Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
Backlight problem on 5s
I think I need to replace the backlight filters. I've read plenty about where they are on the iPhone 5 but can't find anything on the iPhone 5s. Can anyone tell me where they are on the board and where I can buy them? Is this all I will need to replace or should I also replace the coil and ic chip.
Thank you in advance!!
Score 2
1 Comment
You have micro soldering skills and tools?
by
Add a comment
Chosen Solution
I'd check around FL24, FL25, FL26 as well as the capacitors C17, C243 and C18.
further explanation package size
Score 7
11 Comments:
Thank you! This was exactly what I was looking for. Do you know where I can buy the filters and capacitors?
by
Looks like they are all in stock a digikey.com
by
Thanks oldturkey03. Is this the part for the filter? FILTER CHIP 120 OHM 3A 0603
by
Found it (I think) - FERRITE CHIP 220 OHMS 2.0A 0603
by
susan, the three filters are 240 OHM 0.2A 0.8 OHM in a 0201 (0603 metric) package. Available at places like this http://www.digikey.com/product-detail/en...
by
Show 6 more comments
Add a comment
Probably not the cheapest solution, but perhaps consider replacing the entire display assembly, digitizer en all. It's a Much Much easier job.
1 Comment:
I already tried that. I can see the apple logo, barely, using a flashlight pointed at the display, so I think the backlight filter is blown. I'm up for replacing it/them. Can solder, just don't know where they're located. Plenty of info on the iPhone5, not much on the 5s.
Thanks!
by
Add a comment
Add your answer
susan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 2,468
