Stripes on the screen iPhone 5
Board did change my iPhone 5 and I get stripes on the screen please help
change the logic board, when I put the screen when you get to the menu started to put stripes from top to bottom and then damage the screen after interning several times that work, I put another screen and just step.
cambie el logic board, cuando puse la pantalla cuando llego al menu comenzo a poner rayas de arriba hasta abajo y luego daño la pantalla luego de internar varias veces que funcionara, le puse otra pantalla y paso igual.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 446
Can you elaborate a little more as to what you've done to the phone? Did you replace a logic board on the phone?
by Tony Gines
