An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 Questions View all
Why does my portafilter does not work properly?
Why does my portafilter does not drain all the coffee out? I have cleaned the machine many times and taken the portafilter apart but everytime I finish making the shot and take the portafilter out there are still a lot of pressure there and a lot of remaining mixture of coffee and water.
Score 1
Add a comment
1 Answer
Chosen Solution
You may be using to course a coffee grind and it's clogging the filter.
Score 1
1 Comment:
Actually, too fine of a grind will make it harder to push the water through; a too-coarse grind will result in weak coffee that almost gushes out. Tamping too hard will also produce a similar result, and really isn't necessary on this machine as it comes with a pressurized portafilter.
by
Add a comment
Add your answer
Mango will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 3,015
