Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
343 Questions View all
Will not power on, hear a slight fan sound but then nothing.
The machine was running, when I can back to my desk the screen was blank. I tried to power it on but nothing happened. Checked all the cords and removed all external devices. How do I test to see if it's the power supply or something else?
I replaced the power supply as instructed, but the machine still will not start. It sounds a little different when tiring to start, I hear what sounds like the HD spinning. Checked the LED test lights and still only the #1 is lit up.
Thanks
Ian
Score 1
1 Comment
OK, I replaced the power supply but no difference. Maybe the hard drive sounds like its running?
by
Add a comment
1 Answer
Chosen Solution
You need to take a look at the diagnostic LEDs. Take a look at this question for how to interpret them and location: Where are the diagnostic led's on this model's logic board
Score 2
7 Comments:
Try using this guide but not disconnecting the cables yet. Just lean the display forward and see if you can see the LEDs. iMac Intel 21.5" EMC 2389 Display Replacement
by
Do I remove the display first
by
I can not disconnect the LCD thermal sensor cable connector from its socket on the logic board.Does not want to pull off. Am I missing something?
by
I got the display cable off. Plugged the computer in. The only LED light that comes on is the #1. It stays on but that's it. Pressing the power button results in what sounds like the hard drive trying to start up. A couple of clicks then nothing.
by
Show 2 more comments
Add a comment
Add your answer
Ian Hurley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 238
