ps3 yellow light of dead
i have ylod then i open the ps3 clean everything then i remove heat sink using thermal paste then i turn on ps3 still ylod please guide me how to fix
deeracars, first you will have to remember that there are a few things that can cause the YLOD. A few of them are:
A dead or disconnected HDD
Cold-Joint between the CPU/RSX/EE(If your console has one)
A dead power supply
Overheating
Corrupted NAND Flash
You most likely have issues with your GPU processor. It is a flip chip design and the issue could be the solder bumps between the IC and the substrate. A reflow might fix it for a while. The only repair that would fix it permanently is a new BGA. Try this repair first
Thank you very much
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 404
