Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Is my screen's Ribbon Cables defective?
Help! I was replacing my LCD screen and when I first put the screen on with the ribbon cables I noticed there was a white line so I detached them and reattached them and now the screen doesnt work. Then I went to reattach my old screen and it doesnt work either. My phone is vibrating and is fine but now my screens arent working. Did I just do something to the circuits?
Score 1
Add a comment
1 Answer
Most Helpful Answer
Yikes!
Did this happen after you screwed down the LCD shield? Hope not---because that is a difficult problem. Mixing up the screws on the iPhone 6 shield causes a no backlight problem when the long screw is screwed into the wrong bracket and tears the traces in the board. Repairable, but really tough.
But first, rule out the easy stuff. 1--hard reset--lift off the battery connector and reseat and power on.
2--it could be just a blown backlight filter--especially if you're sure you did not mix up the screws. That is still a board repair, but much more straightforward.
Score 1
Add a comment
Add your answer
Lauren Hemingway will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 455
