Difficulty getting into 5th gear. Clutch fluid access?
Bought clutch fluid but can't find out where to pour it?
Cancel
Repair guides and support for cars produced by the British automotive manufacturing company, founded in 1903.
Rep: 1
Rep: 1
Do a google search for "vauxhall clutch fluid reservoir" when you get results, filter your search so you just get results with images. (There will be a choice of results e.g. "web, images, videos... etc). You should see lots of photos of the engine compartment of vauxhall cars with the fluid reservoir shown.
Depending on your model of vauxhall, the clutch fluid reservoir (the place where you put the fluid you bought), will be located somewhere in the engine compartment. It will likely be a white plastic container with a black screw top lid. (Sometime on the lid it will say "clutch fluid" or similar thing).
Remove the lid and pour in fluid until it reaches the "max" level marked on the side of the reservoir. (It can be difficult to see the mark sometimes).
Sometimes the reservoir is located in the back of the engine compartment and there is no room to tip a bottle to pour the fluid into the reservoir. In that case, you may have to get hold of a syringe (maybe 30ml or 40ml e.g.. Find on ebay for £1 or so). Maybe have to fit a short tube on the end of the syringe to reach the reservoir. (It's like this on a vauxhall zafira for example).
There are a few fluid reservoirs in the engine compartment. e.g. there will be a reservoir for steering fluid and another reservoir for window washer fluid etc. Make sure you identify the correct reservoir before you put fluid in.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 170
We have a chance to guarantee our right to repair electronic equipment—like smartphones, computers, and even farm equipment. This is a once-in-a-generation chance to protect local repair jobs—the corner mom-and-pop repair shops that keep getting squeezed out by manufacturers.
Join the cause and tell your state representative to support Right to Repair. Tell them you believe repair should be fair, affordable, and accessible. Stand up for your right to repair!
