A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
Is my ps4 broken
Hi i recieved the ps4 for xmas from my wife so its now only 3-4 months old,the power inlet is slack and therefore is a real pest to get the system up and running when i eventually get going it with no warning cuts off after 20 mins maximum im now really concerned about it.is this something i cood repair myself?because i no longer have the reciept for the playstation and am worried that its been a waste of money
Add a comment
1 Answer
Chosen Solution
The bad news is that yes, there is something wrong with your PS4. The good news is that its probably fixable. There are 2 likely possibilities:
1) If the power cord is loose when you plug it into the PS4 then that could be creating a faulty connection when the console is turned on and you are using it. If this is the case then you would either need to get a new power supply or find someone to fix the power supply. My business can repair most power supplies and there may be others out there as well.
2) Sometimes when a PS4 turns off randomly it's because the solder joints under the APU are faulty. If this is the case it can usually be fixed as well.
I hope this helps.
Score 2
Add a comment
Add your answer
jock will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 489
