Mid 2006 / Model Number: A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor
418 Questions View all
Question Closed
Display affected by hinge
Backlight goes off but you can see the screen with strong external light.
Backlight can be invoked with a magnet placed on the desktop.
Started with recovery done by rearranging the cover angle. Thought it might have been the cable within the hinge until I saw the magnet work. Stays on momentarily and then it reoccurs.
2 Comments
Thanks
I reviewed and see that I have an A1181
does this fit apply to this model. I see that the infrastructure is different? 2009
by
Yes, it does make a difference ;-}
by
Add a comment
1 Answer
Most Helpful Answer
If the screen goes dark again after placing the magnet on the top where the sensor is that implies the hall sensor is bad. If I remember correctly, the hall sensor is part of the hard drive cable. Here's the IFIXIT guide to replace the cable: MacBook Unibody Model A1342 Hard Drive Cable Replacement.
It is also possible the WLED driver has a bad solder joint. But that is a logic board level repair. For now try the cable and let us know how it goes.
Update
You'll need to replace both the inverter and the invert cable.
Here's the guide to follow: MacBook Core Duo Inverter Replacement & MacBook Core Duo Inverter Cable Replacement
MacBook Core Duo Inverter Image
Guide
Difficulty:
Difficult
1 - 3 hours
MacBook Unibody Model A1342 Hard Drive Cable Image
Guide
Difficulty:
Moderate
10 - 40 minutes
MacBook Core Duo Inverter Cable Image
Guide
Difficulty:
Difficult
Score 3
1 Comment:
OK, Nix the drive cable. Your system has an inverter which is likely the issue
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 81
