Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
838 Questions View all
Orderd Hdd cable, and its longer than one in my computer
I orderd Hdd cable for my MacBook pro 13 2009 model.When i wrote this in ebay i got results for cable serial number 821-0814-A, so i orderd it.When i got cable it turned out it is 1cm longer than cable that was inmy computer.Also my old cable had little diferent serial number(821-1226-A).My question is, if it is cable for my computer model why is it longer, and can i put it in my Mac, will it work?When i try to put it it bands.It have same conectors.
Thanks allot for any answers.
Comments:
Can you give us the last four digits of your serial number so we can correctly identify which model series you have.
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Chosen Solution
The problem here is there is three different parts depending on the series and they are different!
I suspect you got the wrong one. The P/N on the original cable is what you should search for. I would recommend you return the clearly wrong cable and get the correct cable.
Score 1
Add a comment
It'll work just fine, don't drive yourself nuts. These cables are compatible and I assure you are all equally bad. Seven years in laptop repair and I have never replaced a drive cable on anything but a 13" Unibody, they are terrible cables!
Just curve it inside the gap between the optical drive and the motherboard and you will be fine.
Most vendors selling these parts are clueless what works with what and just robbing them out of recycled machines. I assure you you will drive yourself nuts dealing with them, so if it works, just use it as is!
Add a comment
Add your answer
Nirelj will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 87
