Everything you need to repair your iPhone yourself! From the newest iPhone 15 lineup, all the way back to the original iPhone 2G released in 2007, iFixit has free repair guides and disassembly information for every single iPhone, as well as the best replacement parts, tools, and tips in the galaxy.
36478 Questions View all
Question Closed
Glass replacement issue that nobody seems to know the answer to
So I don't know did anyone can answer this question but recently I have done an iPhone 6 and iPhone 5 glass replacement. After I cured the uv glue under a uv light I cleaned excess glue off and turned the phone on only to see that the screens were very discolored. I think this is because of the glue but I'm not sure if anyone knows why this happens please respond!
Add a comment
Most Helpful Answer
looks like it got under the lcd :(
Score 1
Add a comment
Hi , this is the issue with cutting Iphone screens and using UV glue to attach a new one. the glue gets between the LCD and backlight. this is what causes what you are seeing. you will require a new backlight. An alternative to loca is OCA - Optically Clear Adhesive (Sticker but needs autoclave to remove bubbles).
Score 1
1 Comment:
Is there a way to prevent the glue from getting under the backlight and how does the OCA work or the autoclave
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 5
All Time: 110
