Problem booting computer without tapping it.
Computer worked fine in the morning before I left. I put it too sleep. Got off the train and decided to use it. It wouldn't come on. So I took battery out, put it back in and tried powering it up again. When I did that you heard the computer come on but nothing should on the screen didn't hear the chime all you heard was the fan just blowing did this many times. Finally I tapped the bottom and it booted but then it froze. I took it apart to see if anything is loose but there is nothing and it keeps doing the same thing.
Score -1
Add a comment
Chosen Solution
First reset the PMU:
http://support.apple.com/kb/ht1431
Try starting up from your system installation DVD. If it starts run disk utilities and repair the hard drive.
If the hard drive is gone:
iBook G4 14" 1.42 GHz Hard Drive Replacement
Score 1
Add a comment
I'm seconding mayer, I'm betting your hard drive is shot. back up your stuff now before it's too late. do it before any sort of repair in disk utility. always back up first.
Add a comment
Add your answer
Jdante7753 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 536
